mirrors won't work?
RUDEONETHAKINGPIN
for some odd reason my mirrors wont work all the fuses say they are good what can be my problem
May 18, 2009 at 1:10 PM
SQM
  • 6,383 POSTS
Unless you have already done it, I will suggest you use a test light to check the fuse.
The fuse is located in the fuse block under the hood.
It could also be a wiring issue. I have attached the wiring diagram for your mirrors.
Here are some helpful articles:
https://youtu.be/Hlna_kUt7As
Jul 21, 2021 at 4:20 AM
