1999 Chevy Tahoe low engine compression #1 cylinder
87,000 MILES • V8 • 4WD • AUTOMATIC
CLARENCE DAVIS
Check engine light came on. Took car to service station. Found code PO300B random multiple misfire detected. found spark plugs had signs of burning oil (fouled spark plugs). they replaced the plugs and then it coded PO3001. They found that cylinder #1 had low compression 120psi and the rest are at 175 psi. Added some oil to cylinder and the compression came up. Mechanic recommends complete rebuild or replace the whole engine. My question is "Is there anything else I can do to fix this problem"?
Dec 12, 2009 at 5:43 AM
BLACKOP555
  • 10,386 POSTS
if it went up enough to make it pass the test then the rings are bad. esepcially since the plugs were fouled with oil. nothing you can really do. besides drive it till it blows.
Dec 12, 2009 at 11:21 AM
