1999 Chevy Tahoe Kelsey-Hayes ABS controller bleeding proce
135,000 MILES • V8 • 2WD • AUTOMATIC
JOHNDEERE730
I know after replacement of ABS controller there is a bleeding procedure beyond the normal 4 wheel bleeding. Can this be done w/o purchasing a set of special tools that cost alot of dough. If there is, could you share that with me please.
Dec 19, 2008 at 1:44 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Bleed at all wheels RR,LR,RF,LF no special tools or proceedure.
Mar 16, 2021 at 2:39 AM
BRIAN 1
  • 1,030 POSTS
it has to be bled by a tech 2,it's called an automated bleed,it pushes all the air out of the ebcm to all the calipers. no other way around it if you don't bleed it this way you will never get the air out.
