1999 Chevy Tahoe intake gaskets
238,400 MILES • V8 • 4WD • AUTOMATIC
CHUCKP
i have a 1999 chevy tahoe i noticed i was leaking antifreeze after some checking i noticed it was coming from the intake gasket on the pass side,after replacing both the gaskets and cleaning all intake and plentiun area and replacing the plentium gaskets. i put the entire thing back together.replaced the distribitor cap and rotor plus spark plugs,then when i start it runs real rough and no power. before i did the gaskets it ran very well and no check engine lights were on. now i have a code 300(rapid missfire-random) cleared that and when i go to start it still runs rough as a 8 day clock.. any ideas would be so much helpful right now i am lost and having no idea what it could be.
May 22, 2010 at 10:29 AM
CHUCKP
[quote:07b2cc4aa0="chuckp"]Engine Performance problem
1999 Chevy Tahoe V8 Four Wheel Drive Automatic 238400 miles
i have a 1999 chevy tahoe i noticed i was leaking antifreeze after some checking i noticed it was coming from the intake gasket on the pass side,after replacing both the gaskets and cleaning all intake and plentiun area and replacing the plentium gaskets. i put the entire thing back together.replaced the distribitor cap and rotor plus spark plugs,then when i start it runs real rough and no power. before i did the gaskets it ran very well and no check engine lights were on. now i have a code 300(rapid missfire-random) cleared that and when i go to start it still runs rough as a 8 day clock.. any ideas would be so much helpful right now i am lost and having no idea what it could be.[/quote:07b2cc4aa0]
May 22, 2010 at 10:37 AM
