1995 Chevy Tahoe Taping noise up top
1995 CHEVROLET TAHOE
140,000 MILES • V8 • 4WD • AUTOMATIC
BEAZY
I just changed my head gasket,intake manifold gasket,and valve cover gasket.My engine is now taping up top only after I let it run for a while,when I am driving and come to a stop my oil pressure goes done as if it doesn't have enough oil. yes I did changed my oil. why am I losing oil pressure? could it be my oil pressure switch or knock sensor?
Nov 18, 2009 at 12:00 AM
PEAR69
  • CERTIFIED EXPERT
  • 1,482 POSTS
The tapping is probably due to low oil pressure. The low oil pressure is probably due to a bad oil pump. The oil pump may have been damaged by debris from the head gasket replacement...Make sure you used the proper head gasket.
Nov 19, 2009 at 2:02 AM
