how to install key ignition for my truck i dont have the key someone stole it so i need to change the ignition.
Jul 24, 2010 at 8:57 AM
FULLMONTE383
MEMBER
first take off the plastics around the column..you will see 3 torx head screws..they must be removed..if you pull the steering wheel it will help but not necessary with experience...unplug wires ..replace..
