1999 Chevy Tahoe head gasket
VCIBRIAN
Engine Mechanical problem
1999 Chevy Tahoe Engine Size unknown Two Wheel Drive Automatic 100000 miles
how can u tell if ur head gasket is broken and how much is it to fix?
Mar 14, 2008 at 9:08 AM
MERLIN2021
  • 17,250 POSTS
Use a radiator pressure tester, see if the leak is the intake manifold gasket...Or do a block test, about 50.00, this will tell you if there are exhaust fumes in the antifreeze. In that case probably the head or head gasket!
Mar 14, 2008 at 9:23 AM
