1999 Chevy Tahoe Fuel pump, fuses
1999 CHEVROLET TAHOE
130,000 MILES • V8 • 4WD • AUTOMATIC
TEAM TESTER
I have a 99 Tahoe that I have replaced the fuel pump on at least three different times. Well this last time after I got it in, and turned the key over, it started popping fuses. It has never done this before after replacing the fuel pump. I am at a loss for what to do now.
Sep 10, 2010 at 6:12 AM
Hi Team Tester, Welcome to 2carpros and TY for the donation
Disconnect the fuel pump connector and see if it pops the fuse-let me know-
Sep 10, 2010 at 9:14 AM
TEAM TESTER
Okay, so we disconnected the relay and it blew the fuse still. So we disconnected the fuel pump itself and it still blew a fuse. Also now my fuel gauge in my dash is pointing straight down and doesn't move when the battery is disconnected and reconnected.
We have replaced the fuel pump 4 times now, and never had these issues before. We double checked the wiring going into the fuel pump and it is fine.
So now we are at a loss for what to do next. Any suggestions?
Sep 14, 2010 at 3:41 PM
The fuse you're talking about is it the Ign E 10amp?
Sep 15, 2010 at 7:03 AM
TEAM TESTER
No it's one of the 20 amp fuses.
Sep 16, 2010 at 2:40 AM
What is the fuse amp and what does it powers, you need a professional help here this can drag on if you're lacking electrical experience -let me know
Sep 16, 2010 at 10:03 AM
