1999 Chevy Tahoe Fuel lines and cooling system
153,336 MILES • V8 • 4WD • AUTOMATIC
H.HERNANDEZ
I 'm currently working on a'99 chevy tahoe trying to remove the intake manifold to replace the gasket since it is leaking coolant but now I am stuck sine there is not much room to work on it and I am trying to remove the fuel lines in orer to get the plastic cover to get to the intake manifold
anyone got any sugestion about how to it or a easier way
Mar 27, 2008 at 11:55 AM
DENNYP
  • 1,824 POSTS
you will need to loosen the flare nuts at the back of the fuel rail. You will need a 5/8in or 16mm line wrench.
Mar 30, 2008 at 11:49 AM
