1999 Chevy Tahoe Error Code P440
101,000 MILES • V8 • 4WD • AUTOMATIC
REEDP79
I recently had my Tahoe in the shop to have the fuel pump replaced. Shortly afterwards my check engine light came on indicating erroor code P0440, evaporative emmissions.
The gas cap is tight!
Any ideas what else could be causing this, especially since I just had the fuel pump replaced?
What should I look for before I have to take it back to the shop that replaced my fuel pump to have them fix what is likely something they caused.
Mar 3, 2008 at 1:54 PM
SERVICE WRITER
  • 9,123 POSTS
This is an evaporative code. You need to talk to the shop that did the pump. Very good chance that something happened during replacement of the pump. IF they smoke the system, it will likely expose the leak.
I have seen situation where fuel filler necks or vent lines have been rotted and is not an avoidable problem. However, it may have been something the shop caused. Need to find the source before deciding if the shop is responsible for the repair.
We had one in the shop like that (ford) that the filler neck was rotted. We only charged the part price and absorbed the labor.
Mar 3, 2008 at 8:57 PM
