I keep getting a random cylinder misfire code. When I drive on the highway and have the throttle at about 3/4 or full throttle after a little bit it starts to misfire. The engine light starts to blink then it stays on. It will misfire for a little while then go back to normal. It also does it when I race it. I'll floor it and when I let off and give a little gas, it will be doing it. Or if I am drag racing at the track it starts to misfire towards the end of the track. I have a new fuel pump, fuel filter, spark plugs, plug wires, distributor cap/rotor, had the injectors cleaned, MAF sensor, intake, cleaned the throttle body. O2 sensors are my next guess. What do you think?
SPONSORED LINKS
Wednesday, March 5th, 2008 AT 3:10 PM
