Tuesday, November 3rd, 2009 AT 3:32 PM
The tahoe has a misfire code P0305 which is misfire on cylinder five the truck has new cap and rotor, plugs and wires check valve springs and compression cleaned all the engine grounds inspected the wiring to the pcm look for cracked injector line running out of ideas
