1999 Chevy Tahoe Broken tension pulley bolt
1999 CHEVROLET TAHOE
112,000 MILES • V8 • 2WD • AUTOMATIC
JUSTINAARON
I think I broke a bolt that hold the tension pulley to the engine (I was replacing the serpentine belt after replacing the alternator). How do I replace that bolt?
Jul 15, 2008 at 4:35 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:667b863078="JustinAaron"]Engine Mechanical problem
1999 Chevy Tahoe V8 Two Wheel Drive Automatic 112000 miles
I think I broke a bolt that hold the tension pulley to the engine (I was replacing the serpentine belt after replacing the alternator). How do I replace that bolt?[/quote:667b863078]
Why do you think you broke the bolt?
If you want the exact bolt you will need to goto the dealer for it, or you can take the broken one and goto your local parts store, match up threads, make sure it is a Grade 8 bolt.
Since it is the Pulley though you can just purchase the Tensioner Assembly and replace the whole thing.
Jul 16, 2008 at 1:11 AM
