1999 Chevy Tahoe brakes light
FRANTZJ
  • 1999 CHEVROLET TAHOE
  • V8
  • 143,521 MILES
None of my brakes light are working I tried changing the brake switch but nothing work I don't know what to do is there anything else I need to do to have my brakes light work again.
Tuesday, March 25th, 2008 AT 10:39 AM
RHALL77
  • 3,361 POSTS
Check the fuses. If they are ok check and see if yo have power to the rear Brake lights.
Tuesday, March 25th, 2008 AT 11:37 AM
ENGIN70
If you have turn signals, and third brake light shines, try jiggling the emergency switch on top of the steering column while you apply brakes Listen for a click when you move the flasher switch lightly side to side. You might find that a short in your dimmer/multifunction switch is the problem. I put a small wedge along the e-switch and the brake lights worked. Though, six months later, I got a lot of "you got no brake lights". I now will replace the dimmer/multifunction switch to the tune of $197.00. I seen some auto stores (online) that sell the part for over $425.00. Shop carefully.
Friday, June 27th, 2008 AT 5:52 PM
