1999 Chevy Tahoe At speeds 60 and above entire car shakes
1999 CHEVROLET TAHOE
80,000 MILES • V8 • 4WD • AUTOMATIC
SAM8642
Tires are wrangler rts 265 75 r16 with 9k on them. Cars always vibrated a little and balancing has helped but not fixed the problem. Front pads and rotors have also worn considerably for 9k milege of use. Mechanic says about 10% is left on them. Vibrations are seen in the dashboard and sears as well as felt through the wheels. The tires standard on these trucks were 245 but the dealer I bought it from said 265 was also an option and shouldn't affect anything. Have run out of ideas. Balances get thrown off easily from the vibrations. What steps should I take to fix and will the vibrations besides annoy me damage the truck?
Feb 14, 2010 at 8:07 AM
  • 110,240 POSTS
The 265 is an optionial size, so that shouldn't cause a problem for you. Have they checked for a bent rim? Alignment? Can you drive throught the vibration. For example, if you feel it at 60 does it go away at 65?
Feb 15, 2010 at 2:12 AM
SAM8642
The faster I drive the more the vibration increases. Just came back from running it on the highway and balancing the front tires has helped a lot but it pushed the threshold of the vibration to around 70. So it still vibrates just at a higher speed. Rims have been checked as well as alignment. Any ideas about a bearing that's worn or could it be connected to a warped rotor? I'm assuming it's unusual for the balancing to be thrown off every 3k or so.
Thanks,
Sam
Feb 15, 2010 at 4:47 AM
