1999 Chevy Tahoe 1999 Chevy Tahoe 2WD - Left Brake Light Wo
180,000 MILES • V8 • 2WD • AUTOMATIC
BIGPOPPA55
I have a 1999 Chevy Tahoe 2WD.
The problem I am having is that the rear left Brake Light will not work when the brake is pressed. To further complicate the problem, this only happens when the headlights are on! When the headlights and running lights are on, the left brake light will not work. The other side and top lights work. When the headlights/running lights are off, the left brake light works!
Ok I have replaced all the bulbs in the rear of the truck. I just read about the brake light switch underneath the pedal today and will check that when I get home today. Any other suggestions? I was thinking fuse, but then the other lights would not work either.
Gotta get this fixed ASAP! Keep getting pulled over by police. Starting to get annoying and I am bound to finally get a fix it ticket soon if they keep pulling me over!!!!
I have donated so hopefully that will speed things up...
Thanks,
BP
Jun 2, 2009 at 2:58 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Check the ground for left light. If ground bad brake light will ground through tail light element but when light on no ground.
Let me know
Thanks for donate
Jun 2, 2009 at 5:38 AM
BIGPOPPA55
Where would I check for the ground wire? I am new at this but I follow directions well. What color? Where would I check?
Jun 2, 2009 at 5:40 AM
DOCFIXIT
  • 18,828 POSTS
Black wire will come out of harness to light and it splices into black wire from right side. Lost groud maybe at socket or at splice.
Jun 2, 2009 at 5:58 AM
BIGPOPPA55
Thanks! Will try it out today and let you know. Hope it is that simple :). Will respond tomorrow and let you know what I find!
Jun 2, 2009 at 6:02 AM
