1998 Tahoe Electrical Problem
SNLNJ
I have a 1998, 4 door Tahoe with 120,000 miles. There is a short somewhere in the car that periodically blows out the brake/directional/hazard fuse. Mechanic and GM dealer have not been able to fix the problem. Any ideas on how to troubleshoot this?
thanks,
Steve
Jun 3, 2007 at 12:34 PM
RUDPRO
  • 224 POSTS
How often does it blow? Do you notice it blowing when braking only? Do you have a trailer light harness attached? I'm looking at a wiring diagram. It's a typical or generic diagram for 1988-1998 Chevy trucks. Is it fuse #1 ? If not, what fuse number is it. Does it happen after it rains? What did the mechanic/dealer replace or do to try and fix the problem? Any more info would help. I would start by checking the wire harness connector going to the rear lights. Follow the wires behind where the bumper is and there should be a connector p in the corner of the drivers side rear fender. Check it for damage from water,etc. More info would help.
Jun 3, 2007 at 6:28 PM
