my wiper motor works but the wipers works sometime
Jan 31, 2009 at 12:16 AM
✓Experienced Mechanic
Hi:
When they stop working, you need to check for power to the motor. If you have power and they don't work, either you have a bad ground or the motor itself is going bad. You could make a ground to see if that helps. If not, replace the motor.
Feb 2, 2009 at 12:44 AM
