1998 Chevy Tahoe what is wrong
156,000 MILES • V8 • 2WD • AUTOMATIC
CHRIS FENDLEY
it has a bad miss to it while you drive down the road and while it is in park it has 50 to52 pounds of perrsure i changed fuel reglater fuel inj. system spark plugs.what could be my promble.
Apr 17, 2009 at 3:14 PM
  • 75,988 POSTS
Your fuel pressure is way too low should be 60-66psi for a 5.7L engine
Apr 17, 2009 at 7:21 PM
CHRIS FENDLEY
what could it be after i changed all those parts,could it be the fuel pump
Apr 18, 2009 at 10:23 AM
  • 75,988 POSTS
Check the fuel filter and intank pick-up sock if its clogged up-if not replace the fuel pump
Apr 18, 2009 at 10:53 AM
CHRIS FENDLEY
i will try that THANKS
Apr 18, 2009 at 11:15 AM
