This doesn't happen all the time but i notice it sometimes. Truck seems to surge coming from a stop sign almost as if the transmission is slipping slightly. I can hit the gas hard and do not notice any slipping. Seems to only be at start from a stop and when up to highway speeds i can feel it sometimes also. The last couple days is smells a llittle hot coming from underneath the truck. Recently had it in for an oil change and the dealership said i have a leak where the drive shaft comes out of the transfer case. Could this be low fluid in the transfer case causing this? I checked the transmission level and the its fine and the oil doesn't smell too bad and it is still red. What should i be checking? I do allot of maintainence myself and the transmission filter and fluid was changed about 1 3/4 years ago and the transfer case was changed 1 year ago.
Dec 3, 2008 at 12:33 AM
