1998 Chevy Tahoe lurching on downshift
MARKREID
  • 1998 CHEVROLET TAHOE
  • V8
  • 180,000 MILES
Recently ready to sell 98 Tahoe. Started to lurch/jerk on downshift under heaving braking to a stop (like clutch not disengaging). Original tranny so decided to fix before selling. Tranny shop determined it needed to be rebuilt for $2k to solve problem (not what I wanted to do but did it). They had problem after rebuild getting into gear but replaced brake switch. I took it home and found that I have the same problem. Obviously they part swapped without diagnosing the problem. Question: if tranny has truly been rebuilt, what else can cause this problem? ECU, MAF sensor, another brake related switch? Tranny seems confused about braking/speed. Dont' want to take it back to the shop with some research first.
Wednesday, August 11th, 2010 AT 9:46 AM
Hi markreid, Welcome to 2carpros and TY for the donation.
Sounds like the torque converter clutch/solenoid is acting up try disconnecting the TCC solenoid and see what happens
Wednesday, August 11th, 2010 AT 7:42 PM
