1998 Chevy Tahoe radiator
1998 CHEVROLET TAHOE
106,000 MILES • V8 • 4WD • AUTOMATIC
NATALIEWIEDER
well my truck wont hold any water in the radiator my dad cant seem to find out why he says it might be a cracked head gasket i was just wondering if it could be anything else because the engine is so big and its hard to see everything so if you could help me out if you have any suggestions i would really appreciate it thank you
Sep 20, 2009 at 3:37 PM
PEAR69
  • 1,482 POSTS
Your lower intake gaskets are probably leaking. This is a common problem with the engine in your Tahoe. If there are no external leaks, the leak can be inside of the engine. In this case oil will become contaminated with coolant -- which will lead to serious damage to the engine..Drain and check the oil asap.
Sep 21, 2009 at 9:53 AM
