Engine is still in one piece. Much appreciated rasmataz. Now I can get back to solving the original problem, which is that I get a rough idle when I'm on the brake pedal and shifted into drive at a stop sign. The engine seems to run smoothly at all other conditions. I do get a P0102 MAF, which I have cleaned. I also get a P0304 misfire but I have now replaced the spark plugs, wires, cap, rotor, distributor, #4 plug again, #4 wire again, used throttle body cleaner on the throttle body and the EGR valve. I'm beginning to think I have an injector problem, or a spider problem, or maybe a vacuum leak?????? Any ideas?
Aug 23, 2009 at 3:21 AM
