1998 Chevy Tahoe noise in rear
74,000 MILES • V8 • 4WD • AUTOMATIC
TAHOE98JR
When I move forward I hear a clanking noise in the rear of the truck. It happens when I release my brakes and start to move forward.
Jan 2, 2010 at 3:42 PM
PEAR69
  • 1,482 POSTS
Remove the drive rear drive shaft and check the u-joints. Then check the rear differential yoke for any movement (side to side and up and down). If there is any movement then the pinion bearing is failing..
Jan 2, 2010 at 7:32 PM
