1998 Chevy Tahoe noise from front wheels ?
1998 CHEVROLET TAHOE
107,600 MILES • V8 • 4WD • AUTOMATIC
HOOTER
my 98 tahoe has develop a noise from i beleve is the front wheels more so the left side it sounds like a ticking noise and it comes and goes and at differnt speeds , should i be conserned or is it a saftey issue? my 2nd questioni is for the air cond.has delopeda a leak in the refridgernt lines that goes to the rear A/C is there a quick repair for this?
Jul 29, 2008 at 10:45 AM
BLACKOP555
  • 10,386 POSTS
first for the ac, you will have to replace the line, there is alot of pressure in there and there is really nothing that can fix it, unless you take it off and try tig welding it. chances are you will need a new line.
for the next problem, sounds likea cv joint issue to me. or a bad wheel bearing would check that out and see how they test out.
Jul 29, 2008 at 12:39 PM
