Sounds like it is antifreeze. The overflow bottle may have purged some out if the level was too high. Or there may be an intermittant leak. I have seen waterpumps do this. You should look in the area the you saw the leak, in the engine compartment to see any evidence of any stains the liquid left.
Are you not getting a volume of air or are you not getting heat?
SPONSORED LINKS
Sunday, March 9th, 2008 AT 6:57 PM
