Change oil, and oil filter.
Change air filter and clean out air ducts, check under hood for damaged wires from animals.
Drain out block AND radiator and refill with coolant.
Drop tank and drain the gas out, and add fresh gas. Change fuel filter.
Disconnect ignition and fuel system and crank for 10 seconds before reconnecting igniton and fuel system to start.
Also you might need a trans rebuild with new bands in it and new fluid and filter because sitting for a transmission is horrible.
SPONSORED LINKS
Monday, March 16th, 2009 AT 2:46 PM
