1998 Chevy Tahoe fuel gauge
130,000 MILES • V8 • 4WD • AUTOMATIC
DEEGAMBLE
fuel gauge not working. can you advise causes?
Jul 18, 2009 at 5:50 AM
PEAR69
  • 1,482 POSTS
It is probably the sending unit in the tank. To access it you must drop the gas tank and remove the whole fuel pump module. The tank level unit is attatched to the module. If you do this or have a mechanic do it MAKE SURE you replace the fuel pump wire harness connector or you will have issues with this connection...
Jul 22, 2009 at 4:15 AM
