1998 Chevy Tahoe fuel gauge
DEEGAMBLE
  • 1998 CHEVROLET TAHOE
  • V8
  • 4WD
  • 130,000 MILES
Fuel gauge not working. Can you advise causes?
Saturday, July 18th, 2009 AT 12:50 PM
PEAR69
  • 1,482 POSTS
It is probably the sending unit in the tank. To access it you must drop the gas tank and remove the whole fuel pump module. The tank level unit is attatched to the module. If you do this or have a mechanic do it MAKE SURE you replace the fuel pump wire harness connector or you will have issues with this connection.
Wednesday, July 22nd, 2009 AT 11:15 AM
