1998 Chevy Tahoe door frame
200,000 MILES • V8 • 4WD • AUTOMATIC
RYMEANYTIME
I have a 1998 chevy tahoe and when i try to shut the door it doesnt close all the way unless i really shut it hard.How can i align it back to its right place
Feb 15, 2009 at 12:10 PM
MMPRINCE4000
  • 8,548 POSTS
Make sure the latch striker is not loose. If not open door and make sure it has no vertical play (hinges).
If OK then spray door latch, hinges with lithium grease.
Check weather stripping, see if it is loose and binding.
If problem persists, remove interior door panel and latch and replace latch.
Feb 15, 2009 at 10:59 PM
