1998 Chevy Tahoe cant get any fire to the coil
1998 CHEVROLET TAHOE
200,000 MILES • V8 • 4WD • AUTOMATIC
ORLANDO.EDWARDS
My truck stop on me the other day. It jerked while I was driving down the street and blew my fuel pump fuse. After replacing the fuse it still wound not start so I replaced the fuel pump. Still it will not start, so I replaced the crank sensor still did not start. Checked all fuses none blown. Replaced Crank module, rotor cap and button still no fire. Could my CPU be bad.
Jun 3, 2009 at 5:45 PM
Did you scanned the computer code/s?
Replaced Crank module-Is this the ignition control module?
Also did you test the coil and distributor pick-up coil?
Jun 3, 2009 at 6:10 PM
PEAR69
  • 1,482 POSTS
Do you have spark?
Jun 7, 2009 at 10:33 PM
