Recently, the lights in my truck started flickering/surging (almost like a power surge). Two days ago it would not start. I changed the battery and got it to start. When at an idle the in dash volt meter shows around 14.5 volts, but the needle "jumps" in line with the surging as well as the flickering of the battery picture in the left of the dash panel. Eventhough the alternator appears to be working properly, could that be causing the problem, or could it be something as simple as a loose connection on perhaps the starter?
Thank you for your assistance.
George
Frisco, Texas
George
Frisco, Texas
Mar 6, 2008 at 12:18 AM
