1997 Chevy Tahoe Spare Tire Removal
MUCA65
  • 5 POSTS
Tires and Wheels problem
1997 Chevy Tahoe V8 Four Wheel Drive Automatic 80K miles
I had a flat tire and AAA came out to try and get the spare off and replace the tire. However, they were unable to get the spare down by putting the hex tool in the sleeve and turning. The AAA tow truck guy swears that the sleeve through which the hex tool goes is merely a sleeve and doesn't do the turning. However, I think he's wrong. In any case, he ended up removing the metal sleeve and now the sleeve won't go back into place and no one can get the spare down. What can I do?
Aug 3, 2009 at 4:16 PM
  • 110,246 POSTS
Is something blocking the sleve?
Aug 10, 2009 at 1:14 PM
MUCA65
  • 5 POSTS
Well, the sleeve seems to just spin now when we try to put it back on, like the connector is stripped or a piece is missing that would hold it in place. There is a hole in the end of the sleeve that looks like a pin could go in there so don't know if something is missing.
Aug 10, 2009 at 1:32 PM
  • 110,246 POSTS
THere should be a cotter pin through that hole that connects the sleve. Look for a hole where it connects. Place a cotter pin through it and see if that helps.
Aug 10, 2009 at 3:57 PM
MUCA65
  • 5 POSTS
problem is how do you get to the spot to put the cotter pin in place? The location is above the spare tire and there is no access for hands to get in there, let alone see what is going on. Is there any other way to get the spare out so we can get access to the space above the spare?
Aug 10, 2009 at 4:24 PM
  • 110,246 POSTS
THere really isn't a way other than cutting the cable. The sleve should push over the receiver and I would think it would turn the release.
Aug 10, 2009 at 4:35 PM
MUCA65
  • 5 POSTS
Ugh.Is the cable expensive to replace? And where is it?
Is it possible that one of the ends could be stripped?
We can (sometimes) get the sleeve to go over the receiver but then won't make a tight fit and just turns freely.
Aug 10, 2009 at 4:42 PM
  • 110,246 POSTS
I believe that is why the cotter pin was there, to make sure it would turn the receiver. THe cable is attached to the steel part that holds the tire under the vehicle. Before cutting it, contact a dealer and make sure the part is available and the price.
ALso, I'm not a body man. Just for the heck of it, call a body shop and ask if they ever had this type of problem after an accident. They may have a trick to remove it.
Let me know what you find.
Aug 11, 2009 at 6:46 AM
MUCA65
  • 5 POSTS
great idea about the body shop - i'll give that a shot.
I'll let you know what i find out and what the dealer says as well before cutting anything. Thanks for all your suggestions and help!!
Aug 11, 2009 at 9:32 AM
  • 110,246 POSTS
Yes, please let me know. I'm anxious to hear what they say.
Aug 11, 2009 at 11:01 AM
