HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Tahoe
Engine
Symptoms
Idle Rough
1997 Chevy Tahoe rough idle & running
LUPE14
MEMBER
1997 CHEVROLET TAHOE
V8
4WD
AUTOMATIC
195,595 MILES
How to fix this small prblm
Friday, December 28th, 2007 AT 12:37 PM
PEAR69
MECHANIC
What is wrong? Is there a check engine light on?
Monday, December 31st, 2007 AT 11:12 AM
Please
login
or
register
to post a reply.
Related Engine Idle Rough Content
Rough Idle - Codes P0151, P0174, P0300
Tahoe Is Running Very Rough At Idle, Almost Stalling. Check Engine Light Is On, Onstar Diagnostic Says To Have Car Serviced, Emissions...
Asked by
dwilson39
2005
CHEVROLET TAHOE
GUIDE
Rough Engine Idle
A rough engine idle condition is a common issue that many drivers face often indicating underlying problems within the engine, fuel or ignition system. We have created this...
Rough Idle And Hesitates When Trying To Accelerate
I Have A 2000 Chevrolet Suburban. It Idles Rough And When I Step On The Gas It Staggers, And Power Is Lacking. Catalytic Converter? I Hear...
Asked by
epyon2k1
1 ANSWER
1 IMAGE
2000
CHEVROLET TAHOE
Water In Oil Five Days After Heads Replaced
Initial Problem Was Water Disappearing From The Radiator At A Rate Of 1/2 Gallon A Day. Then The Engine Overheated And Blew The Head...
Asked by
cmama13
1997
CHEVROLET TAHOE
Why Does 1997 Chevy Tahoe Run Fine At Idle-but...
Cannot Go Over 20 Mph Or It Will Bog Down And Die Out. We Replaced The Fuel Filter, Plugs, Plug Wires, And Upper Crank Position Sensor....
Asked by
debohallo
1997
CHEVROLET TAHOE
Starts Missing And Then Will Not Start?
I Put This Engine In And It Had 117k Miles On It Now It Has 125k I Replaced Plugs Wires Cap Rotor Fuel Filter. What It Started Doing Was...
Asked by
martain1960
14 IMAGES
1997
CHEVROLET TAHOE
VIEW MORE
Vacuum Leak Symptoms
Vacuum Leak
Vacuum Leak Test and Repair
