1997 Chevy Tahoe Front End Stabilizer Bar
1997 CHEVROLET TAHOE
127,000 MILES • V8 • 4WD • AUTOMATIC
MWHIZ
Recently while driving, we hit a bump and the stabilizer bar on the driver side fell out. We purchased a new part and are trying to install the new part. I was just wondering how to install it.
May 23, 2008 at 11:50 AM
PEAR69
  • 1,482 POSTS
I am assuming you are replacing the stabilizer bar. Just remove the old one and put the new one in. There are two bushings attatched to the frame and two bushing kits that attatch the bar to the lower control arm that should be replaced along with a new stabilizer bar. Note--you must remove the plastic round plug that plugs the access hole to the nuts on the lower control arm in order to get access to the lower control arm nut.
BTW--I suggest getting a repair manual.
May 23, 2008 at 7:12 PM
