1997 Chevy Tahoe excessive play
130,000 MILES • V8 • 4WD • AUTOMATIC
WRAMIL315
is there a way to adjust the steering play
Mar 22, 2008 at 1:52 PM
MASTERTECHTIM
  • 4,750 POSTS
no. you must check the front end components and replace the bad parts. most often loose steering is caused by a loose idler arm and or pitman arm. also be sure to grease all moving parts. this will tighten it up alot.
Mar 22, 2008 at 1:55 PM
