1997 Chevy Tahoe engine turns over, no start
NUMBERTWO1081
Electrical problem
1997 Chevy Tahoe Four Wheel Drive Automatic
I have a 1997 Chevy Tahoe, replaced the fuel pump and fuel pump relay. Pump will not run and there is no power at the pump
Nov 30, 2009 at 12:45 AM
JDL
  • 16,098 POSTS
Welcome to the forum, check the ecm B fuse, underhood electrical center. Not only check the fuse, use a testlite on the fuse circuit, should be hot all the time.
Nov 30, 2009 at 1:50 AM
NUMBERTWO1081
Ecm b fuse and citcuit have power, also checked for spark. I have spark. Is there a fusible link on the fuel pump circuit?
Nov 30, 2009 at 10:20 AM
JDL
  • 16,098 POSTS
5.7 litre engine? Do you have dual tanks? There should be a fuel pump test connector, underhood, driverside fender lining, toward the rear of relay pack. Red wire with electrical connector, nothing plugged into it. If you use a jumper wire from battery voltage to connector, the pump should run. You should use an inline fuse on the jumper.
Dec 1, 2009 at 1:32 AM
