Well, first of all, why do you think you need to replace your drive shaft. Usually it is the U-joints that need replacement unless the drive shaft has broken a U-joint and fallen out on the road or some way gotten bent. Drive shafts are balanced and can sometimes throw a weight that is attached to them. Then they start to vibrate at certain speeds, usually highway speeds. As far as repairs go, replacing a drive shaft is pretty straight forward and much easier if you can purchase one with new U-joints already installed. Then it is a simple bolt in deal. Replacing U-joints can be trickier and is much easier if you have a hydraulic press.
You may try sharing the symptoms that you are having with the vehicle with us and why you came to the drive shaft as the problem.
Sep 2, 2010 at 10:22 AM
