1997 Chevy Tahoe Dome light on while driving - intermittent
118,000 MILES • V8 • 4WD • AUTOMATIC
BEMERV
Interior lights flicker on and of while vehicle is running, EXCEPT when the dome light overide button is depressed. I've replaced both left & right front door contact switches.
Aug 1, 2008 at 2:11 PM
98TAHOEGUY
I'm assuming this happens when you hit bumps only, if you have the model with the tailgate this is caused by your rear glass from being out of alingment and not latching tight enough. This happens with my 98' I don't bother with it though i just keep it on dome overide body shop should be able to fix it.
Sep 14, 2008 at 3:20 PM
BEMERV
Thanks for the info. After much trial & error, I discovered that the problem was with a faulty trailer light connector. The lights were assisted in activation by an elderly security system that was about 10 years old. ;)
I traded the vehicle today. Byebye 10-15 MPG!
Sep 16, 2008 at 2:54 PM
