1997 Chevy Tahoe Chevy Taho 97 motor stops while driving
95,000 MILES • V8 • 4WD • AUTOMATIC
SUMMERHILL5
Hello. I have a 97 tahoe (great car, the name in my country is grand blazer), and latelly, when it´s moving and I take out the feet of the gas pedal, the motor stops. I usually put the gear at neutral and turn the ignition key so that the motor starts again. Sometimes it works, sometimes I must stop and try several times before it starts (it all happens with warm motor, and it doesn´t happen all the time).
If the car were an old one, with a carburetor, I would just adjust the "minimum gas" screw, because if I keep the gas pedal slightly pressed, it never stops, but having fuel injection system, I wonder if I must have the injectors cleaned or what else.
Forgive my poor english.
Mar 15, 2008 at 4:29 PM
  • 75,988 POSTS
The check engine light is it On?
Have the Idle air control valve and throttle position sensor
Mar 15, 2008 at 7:23 PM
SUMMERHILL5
No light is On... If I had to make a guess, I´d say maybe there´s some dirty at the gas filter, or at the injectors, but to be true, I don´t know how the injector failure looks like, believe it or not, this is my first car with no carburetor (I had a 1980 Malibu and I loved it so much, I didn´t want to give it up until now)
Thanks
Mar 19, 2008 at 3:03 PM
  • 75,988 POSTS
In today's technology-you have to use special tools and equipment to troubleshoot.
Check the idle air control valve/throttle position sensor/exhaust gas recirculating valve and last the fuel pressure.
Mar 20, 2008 at 10:03 AM
