my battery light in the dash is lit. i noticed that when i hit the brakes while driving, the voltage goes down on the battery gauge. then after i let go of the brakes,the voltage goes back to normal.same with the headlights. is that an alternator problem? also before this problem began, the truck was screaming like a banshee and would stop after about ten minutes of driving unless it's a cold or wet day (it would scream longer). once the battery light came on, the screaming stopped. what gives?
Feb 22, 2010 at 5:31 PM
