1997 Chevy Tahoe A/C Clutch problems
213,000 MILES • V8 • 4WD • AUTOMATIC
VANDEVENTER
My A/C clutch is staying enguaged all the time. I can run the AC and it works fine but the problem is with the clutch staying enguaged it is running my battery down overnight. I have to pull the fuse out in order to keep my battery charged due to the A/C clutch. What is the cause of the clutch staying engauged all the time? It does it even if the air is turned on or off.
1997 model Tahoe 213K miles.
Jul 28, 2008 at 5:55 AM
RHALL77
  • 3,361 POSTS
a short in the wiring or a possble stuck relay. pull the relay and see if the clutch disengauges
Jul 29, 2008 at 2:32 PM
