1996 tahoe code P0161
YEAHONDA
i have a 1996 tahoe LT 4door 4wd..
i have MIL lamp on...i pulled the code P0161(HO2 sensor 2 bank 2)...where is this located??
Nov 6, 2007 at 3:37 PM
HK454U
I had the same problem but bank one sensor one its a oxygen sensor located up on the left bottom of the manifold leading to the catilatic converter it will cost about $70 US dollars but also it could be bad gas 'try a product called Seafoam gas treatment its about $12 US and a tank of hi-test gas
Nov 11, 2007 at 6:47 AM
