1996 Chevy Tahoe Sluggish after valve job
129,000 MILES • V8 • 4WD • AUTOMATIC
ALXTAN
I just had a tune up, valve job work and the fuel injectors replaced on my truck, but when I got the truck back. It was sluggish on hills and slow to accelerate. I kept on telling the mechanic who did the work and he kept on telling me that the truck is fine. So I took his word for it and drove it like that for 3 mos. Then one day the check engine light came on with a misfire on cylinder 8 and a P1351 code. I took it back to the shop and he did a compression check and test drove the truck. The mechanic couldn't figure out the problem. I finally gave up on him and took it to another shop. The new shop discovered that the timing was off by 12 degrees. They fixed the problem and truck ran much better. But now it occasionally would run sluggish. In the mornings it will run great but once it starts to warm up it will run sluggish and I really have to push on the pedal to get it going. There has been a faint burning smell and when I open the door after I have driven it for a while. I can feel heat coming from the bottom of the driver side door. I also noticed that the temp would go over 210 then slowly go back down to about 160-180. What could be the problem? I need to make this vehicle last for another year or more so any help would be greatly appreciated. Thank you
May 9, 2009 at 8:59 PM
MMPRINCE4000
  • 8,548 POSTS
It could be many things, but I would start with the CAT.If timing was retarded 12 degrees, you would get unburned fuel in CAT which could cause it to overheat.
Have a backpressure test performed to see if clogged or partially clogged. This is good starting point.
May 10, 2009 at 1:02 AM
ALXTAN
[quote:c14a7e9f74="mmprince4000"]It could be many things, but I would start with the CAT.If timing was retarded 12 degrees, you would get unburned fuel in CAT which could cause it to overheat.
Have a backpressure test performed to see if clogged or partially clogged. This is good starting point.[/quote:c14a7e9f74]
Thanks for the reply. I will get the CAT checked out. Just one more question, I will have to drive the truck around this weekend and I won't get it to a mechanic until Tues. Do you think it would be okay to drive it around town in this condition?
May 10, 2009 at 7:41 AM
MMPRINCE4000
  • 8,548 POSTS
If I tell you yes, and you wind up towing the car to mechanic, you will not be a happy camper.
Use your own judgement, but if CAT cloggs completely the car will not run.
May 10, 2009 at 11:21 PM
