jack the vehicle up and make sure the trans is in neutral and all wheels are off the ground, having someone push the brake pedal like normally aquired to stop then go and feel each wheel, see if they turn. or if the back ones require extreme pressure to make them work or if they dont push at all.
remember back ones should wear less then the front.
Jun 22, 2008 at 5:20 AM
