So down under the dash at the top of the brake pedal is a brake light switch. Did this get replaced? See if the orange wire it hot. If so, check to see if the white wire has power to it once the brake pedal is pressed in. Or to be easier just run a jumper wire from the orange to the white and see if the lights come on.
If all is good and you have power coming to the back lights when the brakes are pressed in, it should be a ground problem or connector issue under the rear bumper area.
Do you still have blinkers and all that?
Is the third brake light working or not?
Do you have tail lights but no brake lights?
I had a heck of a time with mine. Come to find out my white wire was broken about ten inches past where it comes out of the brake switch just above the steering column (shaft). That was a pain getting to so it could be fixed.
May 30, 2018 at 5:08 AM
(Merged)
