1996 Chevy Tahoe Major tapping and no power in my engine
MBOEMMELS
  • 1996 CHEVROLET TAHOE
  • V8
  • 4WD
  • 105,000 MILES
My 96 tahoe has been ticking like a lifter was bad for years upon startup and would quickly go away then it just started stumbling one day all of a sudden terribly, knocking loudly and has no power. Feels like I took 1 or 2 plug wires off. What common things should I check to solve this problem.
Wednesday, February 11th, 2009 AT 1:49 AM
  • 109,885 POSTS
Does the engine knock sound like the bottom end? Is the miss constant like a plug wire was removed? Is the check engine light on? If you can, take a compression test, and let me know what you find.
Thursday, February 12th, 2009 AT 7:45 PM
MBOEMMELS
It actually sounds more like a lifter. I guess a comp test would show that. It is consistent like a wire (or2) was removed. My buddy that builds hotrods pushed on the gas and brake together and said if it was rod it would get worse with the load on it but it didn't so he doesn't think bottom end but hard to tell. I'll comp test and report the findings and yes check engine light is on
Friday, February 13th, 2009 AT 1:18 PM
  • 109,885 POSTS
Have you have had the computer scanned?
Friday, February 13th, 2009 AT 4:35 PM
