1996 Chevy Tahoe loss of anti freeze
DESANCTIS
  • 1996 CHEVROLET TAHOE
  • V8
  • 4WD
  • 148,000 MILES
I am loosing antifreeze but there are no leaks anywhere, but I can smell it burning off I was told it is probably a crack in the intake manifold what bare your thoughts and how much of a job is it to repair and who do you suggest I bring it to
Saturday, March 13th, 2010 AT 6:47 AM
2CARPRO JACK
  • 11,533 POSTS
Doubt if it is cracked. Those leak coolant at the ends and sometimes it will be just enough to burn it off, so you never see it hit the ground. Check the heater hose fitting at teh Passenger side fron of intake, those corrode and leak quite often as well. Also may want to check the water pump weep hole(bottom of water pump) I have seen them leak a small amount before and get slung around by the pulley and not leave any puddles. You can take it to any certified tech (ASE) and they can repair it for you. It is between 4-5 hours of labor plus parts
Saturday, March 13th, 2010 AT 7:44 AM
