1996 Chevy Tahoe hot starting
90,000 MILES • V8 • 4WD • AUTOMATIC
CHRISPULL
I have had this truck from new and never had any starting problems. Suddenly one day it was reluctant to start from warm. Since then the problem has worsened . It still will start instantly and run normally from cold but even after the shortest of runs with the water temperature hardly registering, it has to be churned over and over and finally will fire up very unevenly and will stall if drive is engaged. After several such sequences, the engine will fire up reluctantly and run ok till the next time I stop and try to restart. Help please
Chrispull
Feb 2, 2010 at 4:08 AM
JDL
  • 16,098 POSTS
Thanks for the donation. How long since a tune-up? When the problem occurs, use a gage and check fuel pressure. Not only check for proper pressure, check that the pressure doesn't drop, when everything is turned off. Some of the national brand autostores used to loan a fuel pressure gage. You can call and ask. Also, they used to check trouble codes for free.
Feb 2, 2010 at 5:41 AM
