1996 Chevy Tahoe high idle
140,000 MILES • V8 • 4WD • AUTOMATIC
STICKSHIFT
the engine idles at 1300 rpms when in park, the wierd thig is that i can put the truck in neutral going 40 mph, and the rpms jump to 2000. They will hang there until I come to a stop. How ever long it takes. Tried a new air idle valve, no luck. Sprayed the intake with starting fluid looking for a vacum leak, no luck either. The throttle plate is completely closed at idle to.
Jul 3, 2008 at 1:27 PM
PEAR69
  • 1,482 POSTS
Check the throttle cable for and signs of wear. Check the throttle plate rod for any sticking or binding. Check it when the engine is cold and also when it is hot -- with the engine off for safety -- we don't want to blow up the engine -- do we? The throttle plate rod eventually wears out and binds up. Lubricating the TB rod is not recomended.
Jul 6, 2008 at 5:14 AM
